1991 Lincoln Mark VII anti-lock brake switch,where is it lo
1991 LINCOLN MARK VII
13,400 MILES • V8 • 2WD • AUTOMATIC
TOBI1992
MEMBER
1 POST
where is the relay switch for anti-brake
Apr 26, 2009 at 10:56 AM
BLUELIGHTNIN6
✓Experienced Mechanic
ABS Power Relay as well as the ABS Pump Motor Relay are located on the firewall, near master cylinder, under cover (pictured below)..
Thanks for using 2CarPros.com!
Apr 26, 2009 at 4:52 PM
