I recently purchased a 1990 Lincoln Mark VII (LSC). This car has not been driven much by the previous owner during the last 4 or 5 years and I have noticed that the front passanger brake sticks after driving only a short distance with regular brake use. I just changed the front brakes and that did not resolve the problem. I have checked the caliper piston and it is definately sticking but I'm not sure if it is a result of a bad caliper or deteriorated brake hose? Any ideas/suggestions?
Note: I have opened the bleed valve with piston in the stuck position and there doesn't seem to be excessive pressure release from the caliper nor does that release the piston.
Mar 19, 2010 at 12:52 PM
