1990 Lincoln Mark VII replace caliper shoes rear brakes -no
1990 LINCOLN MARK VII
LOBITO
Brakes problem
1990 Lincoln Mark VII V8 Wheel Drive Type unknown Automatic 182000 miles
front brakes ok.
rear not working after new calipers and pads
no fluid going to rear brakes
Dec 11, 2007 at 4:33 PM
MERLIN2021
  • 17,250 POSTS
Try turning the key on then carefully open the right rear bleeder, keep body parts clear! anti lock stream can injure you...if nothing comes out, have an aide lightly press and hold the pedal part way down, when stream starts, close bleeder. Repeat on left side. Make sure the bleeders are at the top! calipers can be mounted on the wrong sides!
Dec 11, 2007 at 4:39 PM
