1988 Lincoln Mark VII REAR STRUT CONVERSION KIT
1988 LINCOLN MARK VII
140,000 MILES • V8 • 2WD • AUTOMATIC
BLOOMQUIST
CAN YOU PUT A AIR STRUT CONVERSION KIT IN THE REAR OF MY LINCOLN MARK 7 ONLY SINCE MY FRONT AIR STRUTS ARE ONLY 2 YEARS OLD OR DO I HAVE TO CONVERT ALL FOUR
THANK FOR YOUR HELP
Dec 9, 2009 at 7:58 PM
BLUECOLLAR
  • 86 POSTS
On the Mark VII, there are air springs and totally seperate struts & shock absorbers. A coil spring conversion kit only requires you to replace the air springs with coil springs. In other words, you could just convert one end or the other and still use your existing struts & shocks.
Jul 25, 2010 at 7:44 PM
