1988 Lincoln Mark VII need help
1988 LINCOLN MARK VII
92,000 MILES • V8 • 2WD • AUTOMATIC
TINYMAN
Hello I was putting in a radio and the yellow ground out how the yellow dont have power can you help please red good, black wirer good just the yellow no power
Feb 20, 2010 at 10:21 AM
CARADIODOC
  • 34,381 POSTS
Check the fuses. I can't remember if the yellow wire is the switched power from the ignition switch or if it's the memory circuit. If it's the memory circuit, there is likely some other item that isn't working. Interior lights, horn, and cigarette lighter a circuits that are commonly used with the radio memory.
caradiodoc
Feb 20, 2010 at 9:04 PM
