Car is sometimes hard to start either when cold or hot, Changed fuel pump, filter, fuel pressure regulator, fuel pump relay, had no fuel pressure, changed fuel pump etc as mentioned above, now car has 35-40 fuel presure while idiling or un throttle while in drive, go to test drive and under light exceleration vehicle seems to run fine but if you depress accelerator harder engine stalls and tries to shut off, also under light exceleration going up hill or when you get to about 40 mph same thing happens after this happens it is hard to start, after it sits for a little while seems to start easy again but same problem persists. There was a time in the past that the vehicle would do a simmilar problem about once a month but after driving about 5 miles would clear up then it started happening on a more regular basis, then would not start for about 3 months left it alone for about another month and went to start it and it started fine and ran great for about 2 weeks I put apx 1500 miles on and now have the currant problem I aslo checked the injector electrical with noid light everything is fine, also I checked injectors by listining to them they all sound fine as well.
Sep 23, 2008 at 4:30 PM
