First of all, would need more info. As several scenarios could be playing out here.
If the problem is in the air suspension. Keep in mind that the module(brain) has power to make any adjustments for an hour after shutdown. Anytime after that and the modules' internal clock maybe bad -OR- if the compressor is running OVER 90 seconds, the problem maybe the compressor relay(fairly cheap fix=$25-$40). If it just runs for a short while. But comes on and off, you may have a leak in the system.
Another possibility is that the problem is in the Teves brake system and that you have 2 seperate problems. If the relay for the Teves systems hydraulic motor sticks, it will run all the time. As long as their power in the battery.
SPONSORED LINKS
Sunday, July 25th, 2010 AT 7:39 PM
