1989 Lincoln Mark VI emission test failed
1989 LINCOLN MARK VI
200,000 MILES • V8 • 2WD • AUTOMATIC
JR1812
1989 v8 lincoln recently failed an emissions tes with very high hydrocarbons and carbon monoxide while idling the wierd thing was it passed while in gear any ideas what may be causing the emission problems while idling i was thinking maybe the o2 sensor
Jan 11, 2008 at 11:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:735d743d9d="jr1812"]Other Category problem
1989 Lincoln Mark VI V8 Two Wheel Drive Automatic 200000 miles
1989 v8 lincoln recently failed an emissions tes with very high hydrocarbons and carbon monoxide while idling the wierd thing was it passed while in gear any ideas what may be causing the emission problems while idling i was thinking maybe the o2 sensor[/quote:735d743d9d]
HC high is untreated fuel going throw he exhaust
most common is tune up
check spark plugs and wires
Jan 11, 2008 at 12:05 PM
MASTERTECHTIM
  • 4,750 POSTS
yup i think its the o2
JR1812
Thank you for the replies i'll check the plugs and wire as well as the o2 i'll update after it's done
Jan 11, 2008 at 12:10 PM
