air cabin filter
2006 LINCOLN LS
40,000 MILES • V8 • 2WD • AUTOMATIC
JFW42
where is the air cabin filter located
Mar 26, 2010 at 7:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it's under cowl, have to remove the cowl side trim pieces, then remove the wiper pivot arms. remove the cowl vent screen retainer and disengage retaining clips and position cowl vent screen aside.
Mar 26, 2010 at 7:15 AM
DETELL64
Where is the AC air filter located?
May 15, 2019 at 8:17 AM (Merged)
HMAC300
  • 48,601 POSTS
see pic also to reset Tap the reset button dont hold the first time or it will continue to scroll. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
TSIMS1122
where is the cabin air filter located and how do you change it
2003 Lincoln LS V8-3.9L VIN A
NOTE: The air distribution system of this vehicle cannot be equipped with a cabin air filter.
DEON1414
  • 5 POSTS
[quote:263e64b355="tsims1122"]Air Conditioning problem
2003 Lincoln LS V8 Two Wheel Drive Automatic 671200 miles
where is the cabin air filter located and how do you change it[/quote:263e64b355]
it is under the hood on the passenger side at the fire wall you need to take out the plastic retaining srcews and pull off the plastic cover
