Code p1299 CHT sensor
74,536 MILES • V8 • 2WD • AUTOMATIC
HJ72
  • 23 POSTS
hi, car overheated but it is in failsafe mode. how do i reset? i cleared all codes and i ordered a new cylinder head sensor. i do not what to change it if there is a relearn proceed.help!
Apr 12, 2010 at 11:46 PM
2CARPRO JACK
  • 11,533 POSTS
I take it the vehicle isnt overheating anymore? You may need to replace the CHT sensor, if it is shorted after being overheated it may be sending false signal to the PCM causing the limp mode.When you clear the codes this one comes back ? Mitchell doesnt say anything about a relearn procedure after this has occured
Apr 13, 2010 at 4:00 AM
BLAZEWW420
  • 5 POSTS
My 2003 lincoln ls 3.9L has a check engine light. Just one code P1299 and is in limp mode. Shifting is wonky accelerating at times and the temperature gauge is reading normal. I heard that the overheat protection thing could mess with how the car shifts and as I mentioned the p1299 is the only code. Should I try resetting the ecu first or what is the most likely cause and is it a problem or will the car just stay in limp mode as its not overheating as this code is being tripped?
Jan 29, 2021 at 2:50 PM
STEVE W.
  • 15,394 POSTS
BlazeWW420,
Would it be possible for you to use this link to post this as a new question, The 2005 with a V8 is different enough that it may not be the same problem and adding to the older question gets missed. Thank you.
Jan 30, 2021 at 12:28 PM
