2004 Lincoln LS
120,000 MILES • 6 CYL • AWD • AUTOMATIC
CICELY.BROWN
I have a 2004 Lincoln LS that dies when i come to an idle. My check engine light is on with error codes P2106, P2195, and P2197. What are your recommendations on repairs that i can maybe do without out going to the dealership.
Oct 7, 2010 at 6:26 AM
BMRFIXIT
  • 19,053 POSTS
P2106 Throttle Actuator Control System -- Forced Limit Power
check for ABS codes 1st
P2195 - LACK OF HO2S-11 SWITCH, SENSOR INDICATES LEAN
Description: A heated oxygen sensor (HO2S) indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Possible Causes: Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged powertrain control module (PCM)
P2197 - LACK OF HO2S-21 SWITCH, SENSOR INDICATES LEAN
Possible Causes: See the possible causes for DTC P2195.
Oct 11, 2010 at 11:17 PM
