2003 Lincoln LS running hot
ADAPISCES
Engine Cooling problem
2003 Lincoln LS V8 Automatic
My fans run immediately after turning my car on. It's constantly running hot. I parked it Saturday morning with no problems, but when I drove it Sunday evening it ran hot about a mile away from my house.
Nov 8, 2009 at 9:33 AM
KNOWYOURAUTO
  • 113 POSTS
What is the coolant level? Low coolant will indicate a leak in the system that needs to be found. The fans may be commanded on for a separate reason, but following the standard procedure of checking easy things is always where to starts. If you need assistance doing this here is the link. (note: generic vehicle used) https://www.2carpros.com/first_things/coolant_leaks.htm
Please post back with the information and we will keep going.
Regards,
Nov 19, 2009 at 6:33 AM
