2003 Lincoln LS misfire
BRENT JAMES
  • 2003 LINCOLN LS
  • V8
  • 57,514 MILES
The car is running rough and hesitates on hills and when you give it gas. Check engine light is on and codes are P0302 cylinder 2 misfire and P0316 misfire 1st 1000 revs. Is it a spark plug issue. Just had fuel system flushed.
thanks
Sunday, October 18th, 2009 AT 3:30 PM
Check sparkplug, compression and injector for no.2 cylinder
Engine Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Sunday, October 18th, 2009 AT 3:49 PM
BRENT JAMES
Well it turned out to be 2 head gaskets, which caused problem with plugs and coils.
Thanks for the help
Thursday, October 22nd, 2009 AT 6:45 PM
