2003 Lincoln LS Grinding noise after starting
2003 LINCOLN LS
27,000 MILES • V8 • 2WD • AUTOMATIC
BSTECK
Loud grinding noise immediately after car starts. Only occurs after car sits for 2 or more hours. If car is shut off and quickly restarted there is no grinding noise.
Aug 19, 2010 at 4:22 AM
ERNEST CLARK
  • 1,730 POSTS
If the engine runs fine despite this noise, then it's probably one of the engine's accesories being driven by the serpentine belt.
You can listen for it while the engine is running to narrow it down. If it is coming from this area, remove the belt and turn each pulley by hand until you feel/hear the source of the noise.
Sep 19, 2010 at 11:09 PM
