2002 Lincoln LS spark plugs and ignition coil
CATYVOS1
Electrical problem
2002 Lincoln LS V8 Wheel Drive Type unknown 70000 miles
how do you get to the spark plugs and ignition coil
Feb 18, 2008 at 12:38 AM
MERLIN2021
  • 17,250 POSTS
Remove the engine cover, you have coil on plug system in your car. Each plug has it's own coil. Remove the screw unplug the connector, twist and pull the coil and boot off the plug, use an extension to reach plugs!
Feb 18, 2008 at 12:42 AM
