Fuel to lean, can you diagnose problem? Vehicle has several oxygen sensors
Oct 28, 2009 at 10:12 AM
JDL
✓Experienced Mechanic
Welcome to the forum, how long since a tune-up? Use a gage and check fuel pressure. If you have a code number, the number should tell you which 02 sensor? That doesn't mean the sensor is faulty, it just means the computer thinks there is a problem on that circuit. Any driveability issues?
