2002 Lincoln LS engine light
60,987 MILES • 6 CYL • 2WD • AUTOMATIC
AHUDSON0011
I was driving a couple of days ago and my engine light came on and my car started running a little hotter than it usually does. I could still drive it it would not get hot just run hotter than it did before the engine light can on.
Apr 14, 2009 at 10:01 AM
BMRFIXIT
  • 19,053 POSTS
Check engine light is the messenger and its telling you that you have a problem
scan for codes
codes is the way you can communicate with the PCM
check coolant and thermostat
let me know what you have for codes
Apr 18, 2009 at 5:46 AM
