2002 Lincoln LS blower motor won't shut off
90,000 MILES • V8 • 2WD • AUTOMATIC
DEON1414
  • 5 POSTS
hi on my lincoln when i turn the car off the blower motor continues to run unless i turn it off manually by pushing the off button but it still drains my battery by the next day i have replaced the battery, alternator, and blower motor relay with no luck. also when i start the car the washer fluid sprays on the widsheild for about ten seconds
Feb 3, 2010 at 6:55 AM
BMRFIXIT
  • 19,053 POSTS
1st step should be to run a self test and check for codes
if no scan tool available you can try these steps
let me know what you have for codes or what happens
Continuous DTCs are fault codes recorded by the DATC module which have occurred during normal operation. For the DATC module this means that all faults (intermittent or hard) that occur while the module is in an operational state shall be reported as a continuous DTC.
To retrieve continuous DTCs, press the OFF and PANEL buttons simultaneously, followed by pressing the AUTO button within two seconds.
The DATC module will report all continuous DTCs to the vacuum fluorescent (VF) display.
The DATC module will not carry out a self-test; it will only display continuous faults codes which are stored in memory.
All VF display segments will light if no faults are detected.
Individual continuous DTCs will be reported with the °C symbol lit.
DTCs shall be reported as a four-digit DTC (less the alpha character).
Pressing the front defrost button will exit the retrieve continuous DTCs mode and clear all continuous DTCs from DATC module memory.
Pressing any other button (other than DEFROST) will exit the retrieve continuous DTCs mode and maintain all continuous DTCs in DATC module memory.
Upon exit from the retrieve continuous DTCs mode the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
On-demand DTCs are those that are reported by an ECU when a failure is detected while executing a diagnostic test. For the DATC module this means that all faults (hard) that occur while the module is conducting a self-test shall be reported as an on-demand DTC.
The DATC module self-test will not detect concerns associated with data link messages such as engine coolant temperature or vehicle speed signals. The scan tool must be used to retrieve these concerns.
The vehicle interior temperature should be between 0-32°C (32-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false temperature sensor DTCs may be displayed.
The DATC module self-test through the front panel display:
Can be initiated at any time. Normal operation of the system stops when the self-test is activated.
Is entered by pressing the OFF and FLOOR buttons simultaneously and then pressing the AUTO button within two seconds. The display will show counts of 1 to 25 in the center of the display window. Record all DTCs displayed.
Concludes by reporting all on-demand DTCs. Follow the diagnostics procedure given under ACTION in the DTC index for each DTC given.
Reports individual on-demand DTCs as four-digit DTCs (less the alpha character).
Will calibrate all the mode doors and check all analog inputs. The DATC module will only report on-demand (hard) faults that occurred while the DATC module was conducting its self-test.
Will light all control panel display segments if no faults are detected.
Will report individual on-demand DTCs without the °C symbol lit.
To exit the self-test, press any button. This will clear all on-demand codes from the DATC module memory. If no button is pushed DTCs will continue to be displayed.
Upon exit from the self-test the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
If a condition exists but no DTCs appear during the self-test, GO to SYMPTOM CHART. Condition: The DATC System Is Inoperative, Intermittent or Incorrect Operation.
Always exit the self-test before powering the system down (system turned OFF).
Feb 3, 2010 at 3:12 PM
DEON1414
  • 5 POSTS
hi so i did the check that you said and only one code came up, it was 16 76 c if you can tell what it can be i would appreiciate it thanks deon
Feb 17, 2010 at 12:26 PM
BMRFIXIT
  • 19,053 POSTS
Sorry I search code C1676 with no result at
I will keep looking
Just double check the code again to make sure
Feb 18, 2010 at 11:06 AM
