2002 Lincoln LS battery
100,500 MILES • 6 CYL • 2WD • AUTOMATIC
TUMTEEZY40
my battery dies over a week of sitting idle so i took it to recharge. i got it back and my car continues to die. i had the test ran on my car to pull the codes but my car passed. so im just asking what could it be in general
Sep 28, 2008 at 2:00 PM
OBXAUTOMEDIC
  • 3,720 POSTS
[quote:2f8e62c7b1="tumteezy40"]Electrical problem
2002 Lincoln LS 6 cyl Two Wheel Drive Automatic 100500 miles
my battery dies over a week of sitting idle so i took it to recharge. i got it back and my car continues to die. i had the test ran on my car to pull the codes but my car passed. so im just asking what could it be in general[/quote:2f8e62c7b1]
Was the battery check to make sure it was good?
You can check for a draw on the battery by removing the battery Positive Cable and using a test light connect it between the cable and the terminal, make sure eveything in the vehicle if of, if the light is on you have a draw on the battery. To narrow down the circuit remove the fuses one at a time, checking the light each time. When the light goes out you have found the circiut the draw is on.
Sep 28, 2008 at 2:10 PM
