2001 Lincoln LS steering noises
2001 LINCOLN LS
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDBARON510
hello, i have a lincoln ls 2001, which like 2 days ago started to make a squeaking noise when turning the steer wheel to the right, one day after snow came, probably i need some lubing, thanks 4 ur answer
Jan 30, 2009 at 10:18 AM
MASTERTECHTIM
  • 4,750 POSTS
the front end on these dont have grease fittings so they go dry over time. i use a needle adapter for a grease gun and pierce holes in the rubber boots on the front end components to get grease in there if they are not already worn out
Jan 30, 2009 at 10:21 AM
REDBARON510
hello, its me again, my lincoln 2001, makes an annoying squeak noise when turning the steel wheel to the right, i`d like to know where exactly i have 2 shot with lubricant, a guy told me it was the axle, some other , the ball joint, i hope i will b just lubing, i got this car in jan 15 and everything is fine, just this sound makes me crazy, do i have to pull up the car? or can i do by myself under it, power steering liquid change was performed 1 hour ago and the sound is still there, thanks 4 the answer n have a great day!
Jan 30, 2009 at 10:32 AM
MASTERTECHTIM
  • 4,750 POSTS
i would lube the ball joints and the tie rod ends. you can take it to a shop and they would probably do it for you with a oil change for free if you ask.
Jan 30, 2009 at 10:51 AM
