2001 Lincoln LS Headlamps and dash lights
75,000 MILES • V8 • 2WD • AUTOMATIC
JHARR68
I recently lost a right low beam and a left high beam as well as the tach and speedometer backlights and oddly enuf the passangers power mirror. The lights themselves work just get no power. I have located and checked every fuse in the vech. Could this be in the Headlamp switch? What about the power mirror? Are they even tied in to same curcit? Any Ideas?
Oct 17, 2010 at 3:59 AM
JDL
  • 16,098 POSTS
Voltage at the head lamps is hot all the time. They are controlled on the ground circuit. The headlamp switch sends signal to instrument cluster. The instrument cluster sends signal to front electronic module, behind A-pillar. Maybe a trouble code would point in the right direction?
https://images.2carpros.com/forum/automotive_pictures/170934_lincoln_headlamps_1.jpg
Oct 17, 2010 at 4:32 AM
