2001 Lincoln LS caliper removal
MINNESOTA116
Brakes problem
2001 Lincoln LS V8 Two Wheel Drive Automatic
What tool is needed to remove all four brake calipers?
Oct 16, 2009 at 12:05 PM
MERLIN2021
  • 17,250 POSTS
Only special tool is to screw in the rear pistons to replace the pads. Front pistons just push back with a big screwdriver before you remove the caliper, or C clamp after removing it.
Oct 16, 2009 at 12:13 PM
MINNESOTA116
Is there a special tool to remove the calipers?
Oct 16, 2009 at 1:44 PM
MERLIN2021
  • 17,250 POSTS
Do you mean the caliper bolts? Usuall Ford uses a T-45 Torx.
Oct 17, 2009 at 12:26 AM
