2000 Lincoln LS wont start
HOTT
  • 2000 LINCOLN LS
I have a 2000 lincoln ls with a hundred thousand miles on it. When I try to start it the engines wont rotate at all and the battery is brand new whats wrong with it
Thursday, April 12th, 2007 AT 8:45 PM
TECH1JONES
  • 10 POSTS
Does the starter engage? Does it just click or does it make no sounds at all?
If the starter engages you will hear a loud CLUNK if thats the case then the eng. May be locked up
if it just clicks it may be a bad starter
if no sounds. May be a security problem or some other starting circuit problem
hope it helped
Friday, November 20th, 2009 AT 11:36 AM
