2000 Lincoln LS Sputters After Stop
JSWAN47
2000 Lincoln LS 3.9L V-8, 100035 miles. Will start fine and initially runs ok. After driving for a short period of time when coming to a stop and then trying to take off again, it will hardly run at all. It spits, sputters, misses, sometime backfires and doesn't seem to have any power at all. By patting the gas and prompting it some it will eventually pick up speed and go on. Once up to speed (35-60 mph) it will cruise along ok. If trying to speed up in a hurry it wil start siptting and coughing again till you let off the gas and gradually increase the speed. Have replaced fuel filter, both catalytic converters, all oxygen sensors, plugs, map sensor and one other sensor. Diagnostics originally said catalytic converters on threashold and fuel filter. These have been replaced with oem parts. Please help.
Feb 8, 2007 at 6:52 AM
CLEAVAGE4U
  • 69 POSTS
What codes are in the computer?
Feb 8, 2007 at 12:11 PM
JL1993B2200
  • 7 POSTS
My wife's car is doing the same thing as you described. We've had various cylinders replaced, #2, #4 each at different times because the problem was the same each time. It goes along for about 10000 miles and its back again. Its driving me crazy. And what does the service department tell us?... It's just something with "these" cars....aaarrrrggghhh.
Also, the passenger airbag warning came on and the service tech said something must be stuck underneath the seat. Well, after checking and finding nothing he said "all these cars do that at some point".
This is a truly gorgeous car even at seven years old... BTW only 73000 miles.
I'll check back here from time to time as whatever solves your problem most certainly will solve mine.
Mar 28, 2007 at 9:10 AM
SERVICE WRITER
  • 9,123 POSTS
need specifics to help.
Engine size, year, CODES that are in the computer etc.
Mar 28, 2007 at 11:29 PM
JL1993B2200
  • 7 POSTS
Service Writer, I do not have any codes but my engine is 3.9L V8, 2000 LS.
Mar 30, 2007 at 7:21 AM
SERVICE WRITER
  • 9,123 POSTS
With those symptoms, I find it hard to believe no codes are present in the computer.
Try cleaning the IAC valve.
Apr 1, 2007 at 1:39 PM
JL1993B2200
  • 7 POSTS
Service Writer, what I meant by not having any codes is I do not have them to provide to you and do not know how to get whatever codes are available in the car's computer system.
Apr 2, 2007 at 2:51 AM
SERVICE WRITER
  • 9,123 POSTS
I see......
You can buy a scanner or code reader.
You can take it to an autozone who will read them.
You can take it to a shop or dealer to read them but there will be charge.
I meant IAC motor, not valve. My fingers sometimes just get carried away.
Apr 2, 2007 at 9:52 AM
SMOKEMAN
I have the same problems with my car. i had the cylinders changed in a couple forgot at this time which ones but now i have to replace the valve seals. i changed the plugs and saw all this oil was on em. is this the correct. problem or could be something esle? 3.9 8 valve 2000 ls also
Apr 19, 2007 at 5:44 AM
Suggested Repair
Retrieve stored trouble codes with a scanner or at a parts store, then clean the idle air control (IAC) motor. Continue diagnosis from the codes rather than replacing more parts blindly.
Conversation Summary
A 2000 Lincoln LS 3.9L V8 starts and cruises normally but sputters, misses, backfires, and loses power when pulling away after a stop or accelerating hard. The fuel filter, catalytic converters, oxygen sensors, plugs, and MAP sensor were already replaced. The expert said codes should be present and recommended reading them and cleaning the IAC motor. Other owners reported similar symptoms, including recurring cylinder work and oil-fouled plugs with valve-seal concerns, but no confirmed fix was established.
