2000 Lincoln LS rem
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
PICKLESIMER_24
the dealership told my friend he needed his rem replaced and the problem is that his rear lights all stopped working. they are charging him 1300 but i can get the part for a few hundred if that. Where is it located at? do i need to reprogram anything else when i replace it? how do i test it to make sure they are not ripping him off and to see if that is actually the part i need to get
Apr 15, 2009 at 3:55 AM
BMRFIXIT
  • 19,053 POSTS
What is rem ???
is it PCM
and if so you need to have it programmed and or the car will not start
let me know
Apr 18, 2009 at 5:43 AM
