Check fuse 105 (20 AMP) in the underhood junction box, right front of engine compartment. There is no relay on the cooling fan circuit. If fuse is good then test to make sure fan is getting power. If no power then could be bad cylinder head temperature sensor, hydraulic fan solenoid, a/c cycle switch or the PCM. If it has power but doesn't come on then fan motor is bad.
SPONSORED LINKS
Wednesday, July 14th, 2010 AT 1:05 PM
