2000 Lincoln LS occastional miss
2000 LINCOLN LS
106,000 MILES • V8 • 2WD • AUTOMATIC
SHOCKER1
cylinder shows missfire, and also knock sensor code,its cly. # 4 miss comes & goes what would problem be ?
Aug 19, 2010 at 3:34 AM
ERNEST CLARK
  • 1,730 POSTS
It's either the spark plug/wire, coil, or the fuel injector.
Pull the plug and check it's condition. Then install a spark checker. remove the fuel pump relay and crank the engine. If the spark is weak or occasionally doesn't spark, then it's the wire or coil.
You'll need a stethoscope to check the injector. If you hear it clicking constantly, it's fine. If not, then it isn't firing. If the ignition system checks out and the injector is firing, you'll have to pull the injector and flow test it. (May be clogged)
Sep 19, 2010 at 11:14 PM
