2000 Lincoln LS Dual Climate Control
97,526 MILES • 6 CYL • 2WD • AUTOMATIC
ELCAMINOMAN
When the A/C is on the drivers side is hot but passenger side is cold, what could be the problem??
May 3, 2008 at 2:39 AM
MERLIN2021
  • 17,250 POSTS
Run the self diagnostic test on it by turning the key to on, then press off and floor at the same time, then within 2 secs, press auto, If there is a problem a trouble code will appear on the display...To exit self test, press the BLUE, cooler button this also retains error codes, To erase code and exit, press defrost, choose one of these before you power down the system...post any codes recorded here and I will give you the problem!
May 3, 2008 at 3:04 AM
ELCAMINOMAN
[quote:1c0ddf8442="elcaminoman"]Air Conditioning problem
2000 Lincoln LS 6 cyl Two Wheel Drive Automatic 97526 miles
When the A/C is on the drivers side is hot but passenger side is cold, what could be the problem??[/quote:1c0ddf8442]
I sent a pm to ya.. not sure if these are what we are looking for 88, (small) 8 -188, (small) 8
May 3, 2008 at 5:08 AM
MERLIN2021
  • 17,250 POSTS
Reply to PM:
https://images.2carpros.com/forum/automotive_pictures/62217_DATCa_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_DATCb_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_DATCc_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_DATCe_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_DATCd_1.jpg
May 3, 2008 at 5:09 AM
