2000 Lincoln LS driverside replacing the window regulator
52,000 MILES • V8 • AWD • AUTOMATIC
KWSLIM
i have all visible screws removed, and all the clips off all the way around the door trim .but around the door handle inside the car , it still feels like somethings still holding it on .iam afraid i might mess it up, should i get a manual or do you have a idea.or what manual you think i should get.iam talking about the door trim
Jan 17, 2010 at 9:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
To get the door panel off after all visible screws, pry the door handle bezel off from fronter with flat bladed tool. 2 plastic clips hold it on. Now you will see a hidden screw behind that bezel.
Jan 17, 2010 at 12:27 PM
