2000 Lincoln LS drive side A/C blow hot
160,000 MILES • 6 CYL • 2WD • MANUAL
BJONES111
When the a/c is on the drive side blow hot and alittle cold and the passenger side is cold, what could possible be the problem? I ran the self diagnostic test and i believe this is a code but not sure 88, 8 -188, 8 if this is a code could you tell me what it is. Also where can i get a repair manual for 2000 Lincoln LS?
May 20, 2008 at 4:44 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like your mixing doors are stuck
May 20, 2008 at 10:46 PM
