2000 Lincoln LS COOLING SYSTEM
DANIELHALL
Heater problem
2000 Lincoln LS V6 Two Wheel Drive Automatic 70000 miles
MY WIFE'S 2000 LINCOLN LS SHOWES ON THE GUAGES THAT IT IS WARM BUT THE HEATER IS BLOWING COLD AIR SO I ASSUME THAT MAYBE THE COOLANT COULD BE LOW BUT I CANT FIND WHERE TO PUT THE COOLANT
PLEASE HELP
Dec 9, 2007 at 2:00 PM
  • 75,988 POSTS
No heat you might want to check the thermostat and replace it- cheap fix and also there should be a resevoir bottle to fill when low.
Dec 9, 2007 at 10:01 PM
