hypothetically, what would happen if you removed the catalytic converters from a 2000l lincoln ls?
Sep 4, 2010 at 9:18 AM
ERNEST CLARK
✓Experienced Mechanic
You wouldn't pass an EPA inspection and your computer would through you a code thinking your cat is clogged and/or the O2 sensor after the cat is failing.
The computer will compensate and the car will drive fine.
