2000 Lincoln LS ac/heater
2000 LINCOLN LS
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
GENE9507
ac does not cool because both heater and ac are on at same time. Checked freon level and it is fine.
Jun 13, 2009 at 4:29 PM
JNOVACK
  • CERTIFIED EXPERT
  • 723 POSTS
possible causes could be the heater control valve not closing or the control panel on dash not sending signal to the heater control valve to close when A/C is in demand you will need to check for voltage at the control valve if you have then check the control valve
Jun 17, 2009 at 11:12 AM
