2000 Lincoln LS AC/heater
GENE9507
  • 2000 LINCOLN LS
  • 6 CYL
  • 127,000 MILES
Ac does not cool because both heater and ac are on at same time. Checked freon level and it is fine.
Saturday, June 13th, 2009 AT 4:29 PM
JNOVACK
  • 723 POSTS
Possible causes could be the heater control valve not closing or the control panel on dash not sending signal to the heater control valve to close when A/C is in demand you will need to check for voltage at the control valve if you have then check the control valve
Wednesday, June 17th, 2009 AT 11:12 AM
