2000 Lincoln LS
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMIEWOLF2001
on the temperature switch on dash from cold to hot, it won't switch to warm the car. i need to get some answers before winter.
thank you
Nov 3, 2010 at 2:05 PM
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are..........
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Nov 4, 2010 at 12:18 AM
