2000 Lincoln LS
RBEAL4305
Engine Performance problem
2000 Lincoln LS V8 Two Wheel Drive Automatic
my lincoln is running really rough spitts and sputters while idling, poor power performance, i'm not sure if plugs and wires will help or if has another problem?
Mar 27, 2010 at 11:11 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Mar 27, 2010 at 6:58 PM
