2000 Lincoln LS
SMILLER298
Air Conditioning problem
2000 Lincoln LS Automatic 67000 miles
My climate control os not working properly on the pass. side. They are both set to the same temp an the pass. side is not blowing as cool. I can not even use the button on the pass. side to control the fan for that side. What could be the problem?
Aug 22, 2009 at 7:22 AM
HOGMANMIKE
  • 16 POSTS
sounds like you have a bad flow control valve, there are two of them, one for each side
May 3, 2011 at 6:16 PM
