LINCOLN CONTINENTAL
KAIN420
I HAVE A 95 LINC CONTINENTAL WITH A V8 ENGINE. I HAVE CHANGED THE ALTERNATOR AND BATTERY AND MY CAR STILL READS CHECK CHARGING SYSTEM AND THE BATTERY AINT CHARGING
Jan 29, 2007 at 1:15 PM
JEFTFIELDS
  • 74 POSTS
NOT POSITIVE BUT YOUR VOLTAGE REGULATER MIGHT BE SEPERATE FROM YOUR ALT.AND THAT MAY BE CAUSING YOUR PROBLEM.
Jan 29, 2007 at 1:20 PM
KAIN420
so what should i do if my voltege regulater is seperated from my alternater
Jan 30, 2007 at 12:31 AM
JEFTFIELDS
  • 74 POSTS
if it is you will have to replace the regulater and that should fix your problem.your auto parts store should be able to look it up for you and able to tell you if it is seperate or with the alternater.
Jan 30, 2007 at 10:01 AM
ALLBROWN
  • 27 POSTS
I 2 have had that problem. Look under the hood next 2 the battery 4 a black fuse box. Find the small BLOWN FUSE . Hope dat helps!
Aug 14, 2007 at 12:07 AM
NINERGIRL83
[quote:1478cfbf71="KAIN420"]I HAVE A 95 LINC CONTINENTAL WITH A V8 ENGINE. I HAVE CHANGED THE ALTERNATOR AND BATTERY AND MY CAR STILL READS CHECK CHARGING SYSTEM AND THE BATTERY AINT CHARGING[/quote:1478cfbf71]
ok. i got the same exact problem. i changed the altinator and the battery. still won't keep charge. whats the secret?
Sep 9, 2007 at 11:11 AM
