1995 Lincoln Continental No Spark
HEIRIAN
I have a 1995 Lincoln continental 4.6L with about 200000 miles. Ive had the car for about 3 years now and whenever it gots kinda hot outside, (about 90) the car starts acting up. The rpms would drop really low like the car was about to stall out and then they would jump really high causing the car to jerk. Sometimes the car would stall but would start right back up again. Well 2 days ago I took it out and it was doing the same thing I diddnt pay much attention to it due to the fact that I had not had many problems with it in the past, thinking it would stop after i drove for a few minutes. So needless to say, that was not the case at all, the car died in the middle of the highway and would not start again. The display reads "fuel flow data error" well, i called my dad who is a mechanic and can usually help with this he had me check to see if the fuel pump was still working. I could only do this by ear and it sounded like it was working to me. He then had me check to see if the engine was getting gas and it was not so i replaced the fuel filter, reset the fuel shut-off switch and the the car still would not start. I checked the relay under the hood, it was still good. So i checked to see if the engine was getting fuel again and this time it was but again, the car would not start. I called my dad back and he had me check the spark plug wires to see if I could see a spark jump, there was nothing. So this is where I stand, I do not have alot of money at the moment and I dont want to Have to Tow the car somethere to get it fixed. So if anyone has any information that could help me I would greatly appreciate it.
Feb 9, 2007 at 12:21 PM
  • 75,988 POSTS
If you can hear the fuel pump check the fuel pressure with a gauge if its within specs, for no spark do this troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer
Jun 1, 2011 at 5:25 PM
Suggested Repair
Confirm fuel pressure with a gauge if the pump can be heard. For no spark, check power to the coil or coil packs, coil resistance, distributor pickup coil, ignition control module, cam and crank sensors, and the computer.
Conversation Summary
A 1995 Lincoln Continental with a 4.6L engine surged and stalled in hot weather, then died and would not restart with a fuel flow data error. The owner heard the fuel pump, replaced the fuel filter, reset the fuel shutoff switch, and found the relay good; fuel later reached the engine, but no spark was seen at the plug wires. The expert advised verifying fuel pressure and troubleshooting the ignition system, including coil power and resistance, the distributor pickup, ignition module, cam and crank sensors, and the computer.
