1998 Lincoln Continental Door Ajar
JLSDAVE
121,000 miles
4.6.litre V8
Door ajar notice will not shut off.
I know it is from the right rear door.
It will stop for a while and then without warning come on again. Cause all sorts of little problems.
Feb 24, 2007 at 5:33 AM
BHUGG
  • 157 POSTS
The door switch is probably bad. Does the dome light work with this door? If not, replace the door switch.
Let us know on the forum.
Give those who help a vote of confidence.
Feb 25, 2007 at 3:15 AM
JLSDAVE
There are no switches on the door or the frame.
I got info at another source. Spray with silicone at the latch. Problem solved.
[quote:56d7dbb4a3="bhugg"]The door switch is probably bad. Does the dome light work with this door? If not, replace the door switch.
Give those who help a vote of confidence.[/quote:56d7dbb4a3]
Feb 25, 2007 at 10:55 AM
CINXAV
I had the similar problem, and fixed it simply. There is a control in all the door latches which controls the door ajar functionality. These controls might have got struck.
Use WD40 in all the door latches deep inside using the thin tube. This will solve your problem. I got WD40 in walmart.
All the best.
Feb 27, 2007 at 2:54 PM
Suggested Repair
Lubricate the right-rear door latch deeply with silicone spray or WD-40 so the latch-mounted door-ajar control can move freely. If the warning returns, check whether the dome light responds to that door and replace the door switch if it does not.
Conversation Summary
A 1998 Lincoln Continental owner reported an intermittent door-ajar warning traced to the right rear door. An expert suggested a bad door switch and checking the dome light. The owner said there were no visible switches and that spraying silicone at the latch solved it. Another owner reported the same fix by applying WD-40 deep inside the door latches.
