Code U1039 (Not working)
JESPANA
  • 40 POSTS
1995 Continental 4.6L Miles 144100
The code means Vehicle Speed Signal Missing or Incorrect.
Where is U1039 part located and would I be able to fiix it myself?
I just had a remote car starter installed to my car and now I am getting this error. Would the installment of the car starter cause this error? I just want to make sure that they didn't do anything wrong if so I am going to take the car back to them.
I was reading the install manual and found this,Tachometer Signal Connection.
Oct 14, 2007 at 5:57 AM
JESPANA
  • 40 POSTS
I am not having any luck on this one can someone give me a hand?
Oct 16, 2007 at 1:07 PM
JESPANA
  • 40 POSTS
I took it in to a Ford dealer ship and they told me that the code was a communication error. My alternator was not working correctly and drained my battery dry. So if anyone else comes across this error most likely it’s you’re alternator.
Oct 22, 2007 at 11:35 AM
JESPANA
  • 40 POSTS
The code came back, I replaced the two front wheel sensors and I am going to replace the two rear sensors. The front ones needed to be replace as they were damaged.
Apr 10, 2008 at 7:32 AM
JESPANA
  • 40 POSTS
Well, I replace both front and rear ABS sensors and still no luck.
Mar 10, 2009 at 2:28 AM
