Lincoln Continental Check DCL Message
YAHUAH
check dcl message comes on in my message center periodically. Do you have any suggestions as to what I should be looking at first? It does come and go, but it consistantly comes on periodically.
Thank you
Sep 20, 2007 at 7:39 AM
WRENCH
  • 57 POSTS
Need more info like year,make,model,mileage,size engine,ect. but for now you need to run a code reader and see whats in there, all lot of codes will only turn the light on when its a problem and not leave the light on but will leave a code you can retrieve.
Sep 20, 2007 at 1:31 PM
Suggested Repair
Scan the vehicle with a code reader and retrieve any stored codes. Intermittent warnings may set a code without leaving the light on continuously.
Conversation Summary
The owner of a Lincoln Continental reports a periodic check DCL message in the message center. The expert requests the year, mileage, and engine size, and recommends scanning for stored diagnostic codes as the first step.
