97 Lincoln Continental oygen sensors
1997 LINCOLN CONTINENTAL
FINMAN
I have a 97 Continental with 106,000 miles on it. I recently replaced plugs, wires, and 1 oygen sensor on the catalytic converter. Where is the other one? Thank you for your help. And promise to make a donation if I receive a reply.
Nov 26, 2007 at 8:07 AM
2CARPRO JACK
  • 11,533 POSTS
If it only has one cat, then it probably only has one secondary sensor. The other two should be right after the manifolds in the head pipes, before the cat. These would be the primary
Nov 26, 2007 at 10:04 AM
