2001 Lincoln Continental Engine will not start
141,000 MILES • V8 • 2WD • AUTOMATIC
BARENDSEN
My 4.6L DOHC V8 engine will crank, but not turn over. I have checked the fuel valve shut oof switsh and it apears to be okay. Can you help?
Nov 18, 2009 at 11:24 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 18, 2009 at 11:38 AM
STUBADKINS
I have a 2002 lincoln and I put it on diagnostics and it said theft attemped and no fuel pressure dealer says bring it to them try a different key or disconnect the battery for an hour or so
Oct 22, 2010 at 9:31 AM
