2001 Lincoln Continental Engine will not start
BARENDSEN
  • 2001 LINCOLN CONTINENTAL
  • V8
  • 141,000 MILES
My 4.6L DOHC V8 engine will crank, but not turn over. I have checked the fuel valve shut oof switsh and it apears to be okay. Can you help?
Wednesday, November 18th, 2009 AT 7:24 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Wednesday, November 18th, 2009 AT 7:38 PM
STUBADKINS
I have a 2002 lincoln and I put it on diagnostics and it said theft attemped and no fuel pressure dealer says bring it to them try a different key or disconnect the battery for an hour or so
Friday, October 22nd, 2010 AT 4:31 PM
