2000 Lincoln Continental fuses
2000 LINCOLN CONTINENTAL
73,222 MILES • V8 • FWD • AUTOMATIC
MICKYACES
My car failed inspection because when you put parking brake on the parking light does not lite up on dash, which fuse would be the one to replace. They wanted $40 to run a test to find out.
Dec 1, 2009 at 4:39 AM
MICKEY-D
  • 304 POSTS
All the fuses should be marked as to what they work. I think that car has a switch near the top of the park brake pedal, check to see if it has power, or if the wire pulled off.
Dec 2, 2009 at 5:12 PM
