1999 Lincoln Continental Sounds like a big old boat creekin
83,000 MILES • V8 • FWD • AUTOMATIC
LME
when I turn the wheel left or right it makes this deep creeking noise and sounds like an old boat in a movie....
Also, I just put in a rebuilt transmission and there is a squeek there too, but nothing like the other.
Apr 20, 2009 at 9:23 AM
MIKE H R
  • 3,094 POSTS
try using some lubricant on the rubber parts. I have had it that the rubber would get dry and with each turn the thing would sound like a old boat in rough waves.
Apr 21, 2009 at 1:51 AM
LME
My mhusband thought he did that already..anyother thoughts?
Apr 21, 2009 at 2:56 AM
MIKE H R
  • 3,094 POSTS
it could be from something that is dry and creaking. Sometimes i could something minor to something more serious. I would have the front end checked out to be on the safe side.
Apr 21, 2009 at 11:26 AM
CLOSENCOUNTER
  • 18 POSTS
Hello I have a 99 continental and it did the same thing .it was the ball joints ,and of course wouldn't you know they were the kind with no grease fittings.So I sliced the boot surrounding the ball joint and put grease in it.It worked will make the joints last longer and it is quite.Dana
Apr 2, 2012 at 8:37 PM
MERLIN2021
  • 17,250 POSTS
If your ball joints creak, replace them so you dont find yourself in a ditch.. TOWN CAR has a completely different steering gear than continental, on the spindle there is a stop point that hits the frame in a full turn. A small biy of grease there can solve the problem. If it creaks just going over bumps, check ball joints and control arm bushings.
Apr 5, 2012 at 8:36 AM
