1999 Lincoln Continental Steering Shake
I can get around fine, but by no means am a car expert. Would you be able to break that down a little more for me?
Thanks
Bryant
Thanks Again
Bryant Selko
Suggested Repair
Spin each wheel on the car and check for a bulge or out-of-round tire, especially the fronts, which can indicate a separated steel belt. Replace any defective tire promptly. If the shake changes only while braking, also inspect and replace warped brake rotors.
Conversation Summary
The owner of a 1999 Lincoln Continental reported slight steering-wheel shake during deceleration and braking. The expert first suspected a tire with a shifted or separated steel belt, which can create a bulge and make the wheel shake as it rotates, and warned that this is unsafe. The expert also said warped rotors are more likely if the shake changes specifically while braking. The owner found no visible tire defect and planned to rotate the tires; the expert advised spinning the wheels on the car first to check roundness, especially the fronts.
