1999 Lincoln Continental RADIATOR FAN
113,000 MILES • V8 • 2WD • AUTOMATIC
DIMENSIONFIVE
I HAD THIS ENGINE PUT IN TO REPLACE A BAD ONE.
IT WAS INSTALLED BY A LOCAL GARAGE.
THE RADIATOR FANS BOTH COME ON ONLY WHEN I TURN THE HEATER ON. IT OVERHEATED THE FIRST DAY I HAD IT. THE RADIATOR FAN ONLY CAME ON AFTER I HAD TURNED THE HEATER ON.
THE FANS TURN OFF WHEN I TURN THE HEATER OFF. ALSO WHEN I TURN THE HEAT ON I CAN HEAR THE A/C COMPRESSOR CLICKING ON AND OFF.
Oct 31, 2009 at 3:16 AM
BMRFIXIT
  • 19,053 POSTS
Would suspect coolant fan switch /wrong or bad switch
do you have a check engine light on
and if so check for codes
if the engine was just replace they should check that for you for free
Oct 31, 2009 at 1:45 PM
