1999 Lincoln Continental Radiator cooling fans
140,000 MILES • V8 • FWD • AUTOMATIC
PHILCATMAN
My cooling fans run at high speed all the time. According to my manual I have a (VCRM). I have a fan motor going out and would like to fix fan speed at the same time. Temp. gauge works fine. Runs cool. I believe a heat senor must send information to the VCRM but not sure. Fans start a second or two after car starts. Any hints. Thanks
May 20, 2010 at 3:47 AM
  • 75,988 POSTS
Try replacing the coolant temperatur sensor and see what happens.
Jan 2, 2019 at 9:41 AM
PHILCATMAN
NO offense to Pro Master Rasmataz but if the temp. gauge works fine and the car runs cool what good would it do to change the coolant temp. sensor.
  • 75,988 POSTS
The CTS tells the computer when and when not to engage the fan running at high could mean the high speed relay is sticking
https://images.2carpros.com/forum/automotive_pictures/12900_relay_31.jpg
